Sub-Frame Connectors PROBLEM
Or is it no big deal since I CAN get the bolts to grab full threading on the bar nut. It would probably be fine, but I know I'd sleep better if the rail sat flush against the face of the SFC plate.
I got these kind...
http://speed-eng.com/store/images/UM...%203-Point.jpg
Look at the flat plates toward the top of the pic. Those are supposed to sit flush against the frame rail.
And here's the damage.....
EDIT...
OK, I didn't look at the picture of the frame connectors first.....Use the "plate" on the front of the connector as the "plate" I described above.
Thanks for your interest in UMI Performance! I noticed that you are looking into our 3 point SFC's! When installing them they come with a 5 inch bar nut which will form itself back into place. We have seen that problem time to time it could have been someone who over tightened a bolt or even someone might have used a jack there. If you have any other questions feel free to ask and I will be glad to help!
Thanks
Brad
Thanks
Brad
Thanks
Brad
