removing lower control arms
Old Mar 31, 2009 | 06:56 PM
gcouse7's Avatar
Default removing lower control arms
Help... How the heck do you get the 2 mounting bolts out? can't turn them and can't beat them.Got the nuts off just fine.
Old Mar 31, 2009 | 07:04 PM
vjo90rs8's Avatar
if you can't turn them then you need to get a breaker bar, break them loose, then you should be able to use a ratchet to back them out or tap them with a hammer.
Old Mar 31, 2009 | 07:14 PM
99Bluz28's Avatar
Is this in the front or rear control arms?
Old Mar 31, 2009 | 08:12 PM
araber89's Avatar
From: Holmes County (thats right Amish Country), OHIO
Look for something called PB Blaster. Its your friend and hater of the tough bolts. it comes in an aerosol cans
Old Mar 31, 2009 | 08:13 PM
gcouse7's Avatar
Default help
At this point I don't think I can get a socket or wrench on the bolt heads ( rounded off) so it looks like I will be swinging a bfh. 145,000 mies have welded the bolt heads to the locking plate.
Old Mar 31, 2009 | 08:14 PM
gcouse7's Avatar
Default help
Thanks for your imput guys, appreciate it.
Old Apr 1, 2009 | 06:34 AM
qwk93ta's Avatar
I always have PB Blaster in my garage, it works!
Old Apr 1, 2009 | 06:37 AM
leadfoot4's Avatar
Good question!
Old Apr 1, 2009 | 07:02 AM
UMI Sales's Avatar
Default Problem
Hello
Is the suspension unloaded(off the ground) if so just take a piece of all thread or screwdriver or anything that will fit in the hole and tap it out!
Take it easy,
Brad
Old Apr 1, 2009 | 07:11 AM
nighthawk15's Avatar
Originally Posted by UMI Sales
Hello
Take it easy,
Brad
Beat me to it I usually just smack the end of the bolt with a hammer and that does it but sounds like you've already tried that. Something like a screwdriver or a punch should concentrate more pressure and get em right out!
