94 transam with C5 brakes and LS1 spindles. i need alignment bad!
is this normal to go from lt1 spindles to LS1 spindles and need alignment??? I would have thought that the tie rods would go back to the orignal place. also the wheel on drivers side points left a good 3inches and the wheel on the passenger side points slightly to the right. im using the KORE3 C5 brakets. I went with the LS1 spindles because you only need to cut alittle off the spindle. the LT1 spindle needed alot more cutting.
