Rear End Slamming - Bump Stops?
#41
![Wink](https://ls1tech.com/forums/images/icons/icon12.gif)
billyb, that picture's terrible! ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
99WS6,
Actually If I was running a factory height tire in the rear my rear ride height would be about 25.75" And my car rides good!
But that's because I'm running Airsprings with factory bumpstops cut down 1" and Edelbrock IAS shocks.![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Since you have extra weight in the back of your car(me too about 140lbs), you might want to also consider some stiffer/taller rear springs(BMRs would work).
Some better shocks would help too.
99WS6,
#44
all the stock ruber bumpers are the same, the spacer makes the difference and gm dealers are all on back order (from canada) but you can buy synergy brand you just half to alter them to fit and that pick a part sponser on here has them but double the price of gm!!! also ck this out .http://www.angelfire.com/my/fastcar/suspension.html
#47
LS1TECH Sponsor
The SS/WS6 and Z28/V6/Formula stops are VERY different. Maybe now they've been superceded and drill down to one number, but they are not and were not the same OE.
As for this Synergy brand, I have no idea what billyb is talking about, but if it takes modification to install, I can see them being maybe worse than the SS/WS6 stops. Hell there are urethane stops that can fit (and could sell) but the GM versions are the best ones to stick with in my humble opinion.
__________________
#48
Just an FYI. I just purchased some bump stops from the dealer today. He said there are very few left in GM parts system....somewhere around only 12 and have no contracts for anymore to be produced at this time. Not sure if he was BSing but I would check with a dealer ASAP just incase.
#49
My Garage
Trader Rating: 11
E.S. Part # 9.9137; you'll need to either trim the side of the bumpstop, or cut the lip off between the bolt holes where the BS mounts on the car.
__________________https://ls1tech.com/forums/suspension-brakes/1077298-rear-axle-bump-stops.html
#50
Hi Billy, Unfortunately Energy Suspension doesn't specifically list one for yourmodel. You might however try this page here:http://www.energysuspensionparts.com...Shock-Eyes.htm - Graham Slaughterwww.energysuspensionparts.com ________________________________ Talk to Support Right Now! -----Original Message-----From: dst.graham@gmail.com [mailto:dst.graham@gmail.com] Sent: Friday, March 06, 2009 7:13 AMTo: dst.graham@gmail.comSubject: EnergySuspensionParts.com Support Request : (rear bump stop for 02trans am (rear axle ) ) Received : 2009/03/06 07:13:00rear bump stop for 02 trans am (rear axle )________________________________________Subject : rear bump stop for 02 trans am (rear axle ) Name : billy botelhoE-Mail : bbrcllc@hotmail.com Message : hi i've bought from you before andnow i need a rear axle bump stop from a 02 pontiac trans am and i need themin red thanks
#51
http://www.energysuspensionparts.com...%2E9137%5FRear maybe you will know what i'm talking about now !!!! billyb.
#52
#58
Here you go :
http://www.onlyfactoryparts.com/inde...FScXagodE3YR7A
go to : rear suspension, then bumper back it's #7
FYI, not sure if they have them in stock.
