Drag setup
Old Apr 7, 2009 | 12:38 PM
linn.35's Avatar
Default Drag setup
I need to find someone that can setup the suspension in my car. Is there anyone around Columbus OH that has extensive experience setting an F-body suspension for drag racing?
My car has the following parts on it now:
Front
BMR K member and lower A arms
Strange Adjustable Front Shocks
Hyperco 2.5" Coil-overs
Rear
Compition Engeneering Rear shocks
Stock z28 spring
BMR race adjustable control arms
BMR pan hard bar
BMR extreme duty torque arm
UMI 3 point subfram connectors
Moser 12 bolt
What other rear parts would you recommend to get the car to leave hard and dead hook.
Old Apr 7, 2009 | 04:43 PM
linn.35's Avatar
How about anyone in or around OH?
Old Apr 8, 2009 | 09:45 AM
linn.35's Avatar
So no one has any suggestions and there no shops that want my business? UMI is 300miles and 5 hours from where I live is there anyone closer that has any experience in setting the car up?
Old Apr 8, 2009 | 09:58 AM
BMR Tech's Avatar
Give me a call here at the office and I would be happy to over your particular setup...We do have a little experience with fast cars
Old Apr 8, 2009 | 10:03 AM
z28bryan's Avatar
Look up Madman in the drag racing section. This section tends to lean more toward handling. I wouldn't trust a lot of the drag racing advice in this section if I was going to setup a drag car.
I think an obvious one will probably be LCA's and relocation brackets, putting the arms in the lowest hole. Then if the car doesn't leave straight enough at the track, get a bigger rear swaybar to keep it straight. Disconnecting one front swaybar endlink helps at the track with weight transfer.
Note I am not and have never drag raced at the normal 1/4 mile strip, but those seem to be pretty universal steps to hooking better at the drag strip.
Old Apr 8, 2009 | 10:05 AM
BMR Tech's Avatar
Easy now not all drag racing advice given here is bad
Old Apr 8, 2009 | 10:22 AM
z28bryan's Avatar
Not all of it
I would imagine not all of it is good either
I still wouldn't hesitate to check out the drag section. I think it might be better for drag setup advice, but can't be sure. I just say that because there's a lot of fast drivers in there and I'd probably be in there a lot if I was going to setup a drag car.
Old Apr 8, 2009 | 10:54 AM
linn.35's Avatar
Thank you for the help, I will check out the drag racing section and Lee I will be contacting with you today.
Old Apr 8, 2009 | 12:30 PM
linn.35's Avatar
Lee, it was nice speaking with you today. Thank you again for your help.
Old Apr 9, 2009 | 12:09 PM
BMR Tech's Avatar
Not a problem let me know how the car works out at the track
