brake pad change... simple question
also anybody use bendix ceramic pads? prob gonna go with those
I typically always remove the cap when I compress the pistons. Just make sure you don't have too much fluid in it because it's possible to overflow it. And that's really messy.
and i know this is a dumbass question but where is the cap located? if anybody has any pics i would appreciate it....
I typically don't take the cap all the way off (I don't want junk/dust falling in there), I just crack it. When using a C-clamp to push the piston(s) in (1 in the rear, 2 in the front), put the old pad between the piston and the C-clamp. Take your time doing this, you don't want to **** the pistons in their boar. Just give it a 1/4 turn and feel the piston slide back.
