Spring Compressor
What kind of spring compressors do you guys have and recommend? Is this ok http://www.jegs.com/i/Specialty+Prod...40240/10002/-1 .
On the rear, support the car in the rear on jack stands, raise the rear up a little, remove the lower shock nuts, pull the shock's stud out of the axle, lower axle, springs will fall out.
I bought a power steering pulley puller from them and it had so much casting flash on it that it rendered the tool useless. Remember compressed coil springs store alot of energy and if they let loose they have enough energy to KILL you if you happen to have your face/head in the wrong location. Don 't skimp on a tool could result in death or permanent disability if it fails.
The autozone one works just fine. Yes you pay full price for it first. Just use a credit card and they will refund the full amount back to the card when you return it.
yup that's why i said i'd have to see it in person. the design looks good but if it breaks it could be really bad. the trick to the autozone one was putting the edge of one block in a vise to hold it still. trying to crank it and hold it sucked
