Front shock replacement - help!
Got that dremmeled off. Shock mount won't come off. (Every time I say this, note that I have stood on the shock and pounded the thing fairly hard with a clawhammer)
Got out my cobalt drill bits, picked the 5/16" one, and drilled down literally about 3 inches. Yes, I realize how much that is. (By the way, cobalt drill bits are awesome! It had no trouble with this at all in my Bosch 36v drill.)
Shock mount still won't come off. Noticed there's a lot more metal. Switched to the 1/2" bit and drilled down about an inch. I think this might have been a bad idea. Shock mount still won't come off, but I wonder if I've just ruined it anyway.
I would like to be at work in the morning. Can I save this or do I need to try and locate a new shock mount? Autozone doesn't seem to have them, and Carquest and Napa aren't open. I have an Advance near me, gonna see if they have anything.
Edit: Nevermind; Autozone has it. They list it as strut mount, not shock mount. But do I need to buy a new one? I can get a picture of what I did if you guys need one.
Anyone know where I can get a good shock mount, OEM style, without paying much, ideally offline? I'll order online if I have to, but would prefer not to.
BTW, is it just the front end-link or is it also part of the Front Swaybar itself? The reason I mention is because the endlinks are easily replaced with either "Moog Chassis Parts" versions or even "Energy Suspension" ones. Either are okay in that location. AFA SwayBar replacements go, 35/21 or Sam's 35/22 hollow set would be more ideal than 34/21 (provided a 34" diameter front sway is readily available).
So the Moog parts are definitely better than the Gabriels?
I liked Gabriel, too. I always liked their Ultra shocks for what they are (a low cost but good value shock... not for a Camaro, obviously). My opinion of them overall is definitely down.
