Suspension setup?
Old Apr 19, 2009 | 09:55 PM
Bad98SS's Avatar
Question Suspension setup?
I have a 98 Camaro SS all stock with frame connectors and and rear control arms from UMI. I am doing the suspension first and this car will be primarily a street racer, i am looking for a suspension setup that i can drive with on the street but gets good launches on take off i plan on just running radials no slicks for me, any advice?????
Old Apr 20, 2009 | 07:52 AM
UMI Sales's Avatar
Thumbs up A few ideas for you!
Hello
I figured that I would just throw this out there for you for a suggestion! Look into a set of lower control arm relocation relocation brackets(we offer two versions a weld on and a bolt on) and a adjustable torque arm. The relocation brackets were designed and manufactured to eliminate wheel hop and increase your traction performance by allowing you to adjust your control arms ( we have experienced using the lowest hole gives you the best performance)! And a adjustable torque arm will allow you to fine tune your rear suspension by allowing you to set your pinion angle we suggest -2 degrees. Below is a link to show you what we have to offer.
http://umiperformance.com/products.php?category_id=125
http://umiperformance.com/2205?category_id=130
If you have any other questions feel free to ask and I will be glad to help!
Thanks
Brad
