adjust brakes?
Is there something I can adjust that will take pressure off of the brakes?
I pulled the brake booster to see if I accidently drilled a hole or something in it when I drilled the hole for the master cylinder (I did a six speed swap) , but the thing looks fine. Before I go out and buy a brake booster is there a way to check mine? The Best V8 Stories One Small Block at Time
Disconnect the engine vacuum hose from the vacuum brake booster check valve.
Install a vacuum gage to the engine vacuum hose.
Start the engine and allow the engine to idle until normal operating temperatures are reached.
Check to see if the engine vacuum reading is within the specified normal engine vacuum range. Specification
47-68 kPa (14-20 in Hg)
Turn the ignition OFF.
If the engine vacuum reading is within the specified normal range, proceed to step 10.
If the engine vacuum reading is NOT within the specified normal range, inspect the engine vacuum hose for the following conditions.
Tight connection to the engine
Collapse, deformation or contamination
Cracks, cuts, dry-rot
If any of these conditions were found with the engine vacuum hose, replace the hose, then repeat steps 2-4.
If none of these conditions were found with the engine vacuum hose, then there is an engine vacuum source problem, check the engine vacuum system.
Remove the vacuum brake booster check valve from the booster.
Install the check valve to the engine vacuum hose.
Install the vacuum gage to the check valve.
Check to see if the engine vacuum reading is maintained within the specified normal engine vacuum range. Specification
If the engine vacuum reading is maintained within the specified normal range, proceed to step 18.
If the engine vacuum reading is NOT maintained within the specified normal range, replace the brake booster check valve, then repeat steps 11-15.
Inspect the brake booster check valve grommet for the following conditions:
Firm connection to the vacuum brake booster
Deformation or contamination
If any of these conditions were found with the check valve grommet, replace the grommet.
