wanting to replace stock brake system
"Best" is relative, and depends on the use for your car. For street use, the stock breaks are plenty. For track and road racing, there are many setups that can be used. For show, you could get the biggest brake setup out there. Basically it all depends on your goals and your budget. I would start out by searching and learning about what the different setups are out there for your needs. You could get some quality pads, a brake fluid flush, and some stainless lines and be happy. Or you could buy a big brake kit from the sponsors, or even put together your own kit.
I'm wanting to someday get a twin turbo system in which will give the car alot more HP. So I want to give the brake system the proper boost. I'm not even sure what brands to look at so any help will be greatly appriciated.
C5 Brake Suggestion!
I just wanted to suggest this to you that UMI Performance offers a C5 brake upgrade! Below is a link to show you what we have to offer.
http://umiperformance.com/products.php?category_id=117
If you have any questions about anything feel free to ask and I will be glad to help!
Thanks
Brad
