I put a new panhard bar on and....
I understand that poly bushings can create slight bind when they are required to pivot, aka when the axle becomes angled during a turn. Do they also create a rotational bind, within the bushing as well? I'm asking because I don't know. Is the inner bolt sleeve on a poly bushing bound to the bushing itself or is that portion allowed to rotate?
This is a serious question, so please experienced answers only.
And sorry for the thread hijack OP
this is definately true i have a bmr with the double adj. rod ends mines not that loud but you can ocassionally hear noises then again my car is loud period so maybe im just not hearing it as bad but it centered my rear end and made the car a whole lot more stable under a WOT launch.
I get an annoying clicking noise back there,the rear also feels alot stiffer..Not as much give and I can feel every crack in the road now.I'm assuming its because the rear is more spread out so the suspension is traveling less. But the rear is straight now..
Something I have found with rod ended suspension components is if the rod end is sticking during it's movement it will produce more noise. I recommend a dry graphite type lube so it does not try to attract additional outside contaminants like oil will to the rod end.
Any info on this lube or where to get it? Also what kind of service interval for lubing the rod ends? Is it lube it once and leave it like the stock busings or a normal maintenance item. If so, what is that interval? Thanks
The service interval is going to depend upon the environment. The harsher the environment like high dust,or the exact opposite very wet is going to require more attention to keep them in good operating condition. The best thing is to maintenance them with every oil change.
We recommend trying to tighten all suspension components down with the vehicles weight on the suspension. Is it absolutely necessary maybe not... is it going to ever hurt....never
