Need help with Alignment!
After alignment See above for before
Camber L -0.1 R -0.1
Caster L 4.5 R 4.1
Toe L 0.03 R 0.02 Total toe 0.05
That is as close to you all specs that I could get. I am running totally stock. My main concern is even tire wear. I noticed it doesn't feel as tight on the highway speeds. It wonders just a bit more than it did. The dealership was pretty much not happy with me when I left because I took so much of their time. They had no problem charging me the 60.00 again after 3 months.
Any comments welcome.
I wouldn't be concerned about your toe settings, because a little toe is good.
I agree.......
Are you sure this "person" knows ANYTHING about aligning a car? The caster is not "adjusted" by turning the steering wheel. During the alignment procedure, a tool is placed between the steering wheel and drivers seat, to make sure the steering wheel is centered, and doesn't turn during the alignment process, especially when setting the toe. Any changes that are made, are done under the car.
The 4th gen F-body has a lower control arm that has two large bushings, and bolts that go through these bushings. One bushing, the one closest to the front of the car, is in the horizontal plane, and the bolt that retains it rides in a slot in the K-member. This is moved "in and out" to adjust the camber.
The second bushing/bolt is toward the rear of the control arm, and is oriented in the verticle position. This also rides in a slot in the K-member, and this is moved to adjust the caster. (Kent-Moore tools makes a turnbuckle type of tool to help move the a-arms during the alignment process, and it makes the job a LOT easier).
This isn't rocket science, however it isn't a simple 15 minute job, either. As "vjo90" mentioned in his post, you don't set the camber by itself, then make another, unrelated adjustment to get the caster. You have to finesse the adjustments together, in order to get it right.
I know this job from personal experience. Last year, I retired, after 37 years of "factory work". I recently took on a part time job, driving a delivery truck for the local Advance Auto Parts store. Next door to us, is a GoodYear tire store, and I was able to use their alignment rack to do my car, as I had put new tie rod ends in it, therefore it needed to be reset.
I'll admit, it took me two attempts to get it "right on", as the first time I didn't have the tool that I mentioned, and trying to move the a-arms in small increments with a long screwdriver just doesn't work too well. The second time I had the tool, and it went a lot smoother and more quickly, but still took about 45-50 minutes.
If he didnt have the tool for the control arm it would be a bitch to do just because its easier to pry the control arm out making camber negative than it is to pry it back towards the center of the car.
Also, in the event that the control arm was adjusted (front and rear bushings) then its possibly your springs may be a little too worn to give the correct camber specs with the correct caster at the same time. Takes some old *** springs to do that though.
Some of these other shops wouldnt even touch my car saying they didnt have the special tool for the alignment.
Try to find someone who knows what they are doing, when you do get the lifetime alignment.
The guy where i got my lifetime alignment is really good.
I just had him set my alignment for autox...came out good.
-.8 camber both sides
0 toe
5.8 caster both sides
when i say both sides they are within .1, so close enough!
Car feels really good with the -camber, sounds like -.8 might be alot, but not really, IMO they should have come like that stock.
For RR and autox, you want even more, but the stock bushing hold you back.
I'm looking into replacing them to gain a little more - camber.
Good luck
On the Hunter machine, yes, you do the sweep during the initial set-up, when you're starting the alignment. After that, you don't need to move the steering wheel again, as the machine's computer takes both caster and camber readings at the same time. It is, however, a good practice to release the steering wheel lock tool and do a "final sweep" before you take the car off the rack, to double check things.
If you're using a pry bar instead of the Kent-Moore tool, and you go too far negative on the camber, all you have to do is run the jacks under the cross member, loosen the bolts, lift the car a tad, and push the a-arm back in, snug the bolts, and start again...
As I mentioned before, while I'm currently running at 5 degrees caster on my LF, and 5.5 degrees on my RF, I previously had it set at 6 and 5.5 degrees respectively, without having to resort to any unusual "stunts" to get those numbers. Any chance your LCA bushings are shot, and nobody has seen this?
The "low" caster settings will give you a little less straight line stability at speed....
