moser 9 inch problem with sway bar
here's my problem. My rear end sitting forward on the drivers side and I finaly noticed that the sway bar is resting on rear end and were the torque arm bracket bolts to. (it's the one on the far left)
has anyone had this happen? if so how did you fix it?
All the rear suspension is adjustable.
thanx
thanx
well I know I could not use my stock sway bar with my 9 inch im a little confused on what you are trying to say but to fix my issue I just used 3 inch muffler clamps as mounting bracket
