Alignment without wheel lip
The problem is my wheels don't have any lip on the face for the alignment machine satellites to lock into.
Anyone know of an alignment rack that doesn't require a wheel lip and who would have it??
Also there are several adpators to use on custom wheels that hook onto the lugs and never connect to the wheel some also connect to the tires and not to the wheel
SO there are several ways to align without danage to the wheels
remenber where there is a will there is a way, just look for the right person who knows how to use the equ. ask around then talk to the tec doing the work
good luck, Johnny
good luck, Johnny
Thanks for the help guys.
good luck, Johnny
i would go this route. find a place that can use an adapter and doesn't put the target/sensor between your rim and tire because there's always a possibility that who ever does your alignment may put small nicks/scratches on your new wheels when tightening down the equipment.
There is one other alternative, but I'm not sure if it would work properly:
I have a set of 16" salad shooter wheels off of a V6 with a lip that would work perfectly...but does anyone know if going from 215/60/16 tires for the alignment to 245/40/18's afterwards would throw the alignment off?? Ideally I'd like to get it aligned with the 18"s, but if I could use the 16" and have it come out the same, that would be excellent.
