clunking trans
Old May 27, 2009 | 12:52 AM
therobman's Avatar
Default clunking trans
i have a 2000 ta with a t56 i just changed the torque arm bushing and trans mount and checked my torque arm when i shift if i let off the clutch to fast i get a clunking sound is that normal or can i do something to change this it really bothers me. maybe motor mounts they are stock with 41k on them
Old May 27, 2009 | 07:11 AM
UMI Sales's Avatar
Default Poly or Rubber?
Hello
Did you put a new urethane bushing on? If so they might make a little more noise compared to the factory rubber!
Thanks
Brad
Old May 27, 2009 | 10:28 AM
Major_Lee_Slow's Avatar
I get a clunking sound as well when I leave hard. I found that it's my Y-pipe on the drivers side hitting my floor pan. I do have a poly trans and torque arm mount.
Old May 27, 2009 | 10:44 AM
therobman's Avatar
it was there before after the torqure arm bushing its better but still there its only when shifting its deff the trans like clunking around and i just installed my new ls7 clutch too
Old May 28, 2009 | 12:07 PM
therobman's Avatar
k i removed the center console and rubber boot and took it out for a drive the trans was not moving it seemed like it was the exhaust or tq arm any ideas?
