stock torque arm with umi relocation crossmember
how well does this work? does it at any vibrations or change the pinion angle? i also have a moser 12 bolt. any help or experience with this setup would help me out a ton
A suggestion for you!
What I would suggest is if you are looking to change the pinion angle go with a adjustable torque arm. The set up that you are talking about will change your instant center and your pinion angle. But it will either be stock and it is hard to say what the other angles will be. If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
the tunnel mount one? i had spohn tunnel mount but it was to noisey for me. it would clunk, bang and bottom out. it did help my 60's and the quality was good, i just drove my car every day and pittsburghs roads suck. i switched back to the stock setup and now i have a umi relocation crossmember and a bmr adj torque arm and it's pretty smooth.
