Coilover ride height question
Whatever ride height you want it is fine just as long as you keep and eye on the pinion angle. I have heard that the reason for the cars always leaning is due to the motor and drive train it offset towards that passenger side. So if you are using a different rate of spring it would probably show a little more. If you have any other questions feel free to ask!
Thanks
Brad
Hello, you can set your ride height to what ever you like. Keep in mind that if you lower the front too much it will throw your alignment off. Thats one of the benefits of coilovers you can set it to what you want. Also after you get it where you want it verify that your pinion angle is still ok. If you have any questions please give me a call.
