Abs inop/trac light on--help??????
2002 trans am ws6-ramair
abs light/trac light comes on as soon as i drive it.then it`s abs/brake light.when the trac light is on i feel a pulse in the brake
then the track light goes off and the abs/brake light stays on.
Most common is wheel speed sensors and/or wiring connectors going to them. Need to trouble shoot to see so you don't just throw parts at the problem. You can always just swap in known good sensors if you have access to some for free. Could be the module but that is way less common than the above.
