Help H/C Car. What do I get First?
I am finally putting together heads and cam. Its my DD car I want handling mostly. What are the First things I need to get for car. I heard to get subframe connectors to stiffin car,(which ones) So I just want to know what are the first things I need to get. Most Important.
I will occasionly take it to track but not often. Thanks
Hello
I would suggest looking into a set of SFC like you they will keep the vehicle solid. And then a set of sway bars and a good set of springs or shocks. And when you are looking for better traction then look into an adjustable torque arm and a LCA's and relocation brackets. Below is a link to show you what all UMI Performance has to offer!
http://umiperformance.com/93-02fbody
If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
Thanks
Brad
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Step 1: get Konis
Step 2: consider lower front perch/hose mod
Step 3: consider lowering springs
Step 4: SFCs, sway bars, LCA relocation brackets, adjustable PHB after that.
first thing you will hear is that konis cost too much. if cost is a big concern then stop after step 2.
