Heater Hose Mod Writeup
#101
Here is my DD 98 with the heater hose mod and and a coil cut out of the front
I like the way it looks but the heater hose mod was a very small change.
Thinkin about taking it out and cutting the coil, and putting the isolator back on.
EDIT: The springs just fall out if you take out the lower bolt holding the shock... 3 minutes more work and it comes out like butter
This is what I was going to do. Although I have a few questions before cutting the old springs. I only want to lower the rear 1/2" - 3/4". The front I'd like an 1". I thought of only cutting the front springs & using drag shocks front & rear. I was only going to do the hose trick in th rear, not cut them.
1st: Can anyone tell me if I'm asking for problems "cutting the front springs"?
2nd: What shocks are best to use for a street application?
3rd: Am I going to have good enough weight X-fer using the stock springs?
4th: Do I need to have an alingnment after doing these mods?
#102
I ADDED the heater hose (retained isolator) on mine to bring my Pro-Kit up about a 1/2" or so in the back.. Or just the hair that I needed to get to STOP bottoming out in back.
#104
help
hey, just did the heater hose today came out looking sickk! but its slanted, the driver side is higher. i tried turning the spring but its still slanted. what should i do? should i cut the spring? but if i cut it wouldnt it be bouncing. what do you guys recommend?
#105
Silly question for you. Is your car on level ground and are you sure your springs are the same length? Sometimes spring length is different between pairs of springs. I tried a different rate rear springs once and after they had settled I ended up going back to my lighter ones, but what I noticed is that my heavier springs had settled/compressed to different lengths. Alot of cars have a little lean in them. It seems to be a common thing with f-bodies. As far as cutting one spring, I don't know what effect that would have or how it would effect the front ride height. I think most people just live with the leaning.
#106
#107
Just got done an hour ago...... for reference :
On a 98 Camaro SS with 150K on the clock.
My rear springs are the original stock springs. I cut them both 3/4 of a coil & removed the isolator which I replaced with about 12" of heater hose only.
With this done I got a 1&3/4" drop. It appears even. I needed every bit of that 1 3/4 inch drop too!! I think my SS came off the line as a special 4x4 version or something.
#113
Just walked in from doing the heater hose, still kinda high, and the front sits at 28 inches, the rear at 27. I want to cut a coil out of the front and half a coil from the rear. All temporary till I have enough saved for my koni/bmr set up
Don't mind my missing center cap, it's being ordered.
#118
If anyone was interested in removing the isolator lowering the rear and still keeping Oem like nvh in check I make these..
https://ls1tech.com/forums/suspensio...-interest.html
#120
