aftermarket k-member help!
I bought an aftermarket k-member that requires you to use your own engine mounts, and bolt the mount pedastals onto the k-member.
Well I just noticed the factory bolts thread into the factory k-member, and the aftermarket K, just has bolt holes. Well I checked the box that it came in and there were no bolts/nuts in it. Im not sure if maybe they fell out or maybe were just forgotten but now I dont know what hardware to use to fasten the k-member to the pedestals and it is the weekend so I cant call the shop and my car is on jack stands in the driveway.
If anyone knows what hardware is used that would be great and I would go out and get some so I can finish this job!
Well I got it figured out so figured I would post up the solution for anyone who will ever run into the same problem.
I used 7/16 grade 8 bolts, 1-1/2" long, with lock nuts and I used some fairly thick locking washers on top.
