C5 13" Brake Upgrade on my 2000 SS - PICS!!
I'm selling the front and rear brake system off a 2001 C5 corvette.
They have 14k easy miles and are in excellent condition(infact still on car). The car has never been autocrossed,drag raced,or in the rain. I am upgrading the brakes to go with the new cnc forged wheels I just bought.
4 calipers front/rear - very clean, seals,pistons,boots are excellent
4 rotors front/rear- perfect condition,no turnning required,no rust
4 sets of pads - 60% life left
Everything listed..............$300 plus shipping
Caliper brackets not included.
Kyle@midstate-electronics.com
Go to http: www.nashvillespeed.com for the adaptor brackets and instructions needed to do a C5 brake upgrade on a F-body(many pictures).
Originally Posted by CANNIBAL
Why does the LG kit not require removal of the ear on the spindle but this setup does? I'd like to do the 13" rotor and ZO6 brakes on the front and rear. Is it possible on the rear?
So I assume it's not possible to do the rears in 13"?
i need to replace pads and rotors
because of that,
i have convinced my better half to fund a c5 conversion
but first i have a few q's
1. what is the performance difference between the c5 and the c5 ZO6 brake conversion?
2. would it be cheaper to order piece by piece or just by the complete set, and in either case where should i order from to get a good deal? i dont want the old lady to pull the plug on this deal, you know.
3. (irrelevant bling question) if the ZO6 braking system is better, can i get the ZO6 setup, but have black calipers w/ red "corvette" writing on them? (look nice on a black trans, methinks )
and last, before this idea, i planned to get some cheap-*** $40 rotors from autozone and have a buddy of a buddy at a machine shop drill some holes in them. if i do this c5 conversion, can i still get cheapass rotors? i dont like the idea of spending ~$500 for two rotors.
and sorry for misspelling "rotor" backwards,
i tend to ramble on im sure you already know
because of that,
#32
Originally Posted by miner_49
I thought that the C5 and Z06 brakes were identical except that the Z06 calipers were powder coated red instead of gray (cost the same too).
#33
because of that,
because of that,
#34
Originally Posted by mitchntx
With enough $$$$ anything is possible.
There might be some issues with the E-brake.
#35
^ No more goofy than most other front engine cars out there, since most of them run smaller rear rotors. The front brakes do 70% or more of your total braking, so why put heavier unsprung rotating mass on the rear wheels than are absolutely unnecessary? Goofy? Nah.
Doing so may even hinder performance if it throws your brake bias way out of whack. You have a proportioning valve that applies more pressure to the front brakes than the rear brakes. If you applied equal pressure, your rear brakes would lock up (or in our case engage the abs) well before the fronts reached maximum braking. If you increase the braking capabilities of the rear brakes at the same brake pressure, you're throwing that bias out of whack again and could really hurt your stopping ability as a result. If you do want to go this route, you should also install an adjustable proportioning valve. These come with many of the aftermarket brake kits for this very reason
#37
Originally Posted by WILWAXU
Yup! What he said.
In fact.. there isn't alot of difference in the F-body and the vette calipers.
The gap between the outer ears and the caliper pistons is about 1/4" wider.
The ears are thicker
The pistons are smaller diameter, but thicker material
There are reinforcing ribs that travel across the top and around behind the caliper
They are pressure cast
#38
I guess "isn't alot" is a relative term.
