c5 brake conversion brackets
With the C5 Upgrade kit you will have to cut the ears off of the spindle. Below is a link for the directions. And if you have any other questions feel free to ask and I will be more than glad to help!
http://umiperformance.com/page.php?page=c5install
Thanks
Brad
They all the same, only different is material and craftsmanship. Some use aluminium CNC while some use steel CNC and weld. You SHOULD use C5 caliper with the big rotor to avoid bais. Not sure LG braceket use which caliper. There's some non-sponsor bracket will work the same. I've them and they work perfect.
With the kit and Kumho v710 I was able to do 10 70-0 stops in less than 210 feet each time, at the carcraft real street elimator competition
On the other hand, all the cutting required conversion bracket will accept C6 Z51 rotor (13.5") with regular C5/C6 caliper, or C6 Z06 rotor (14") with C6 Z06 caliper. To me, it doesn't matter the brand. All matter is the function. If you don't go any further than C5 rotor, non cutting bracket is fine. However, if you MIGHT wanna upgrade one day, you'll better with the cutting bracket.
One more option is CTS-v conversion, require no conversion adaptor. Check the other thread started by JasonWW. It'll cost more money but worth it. FYI, my C5 conversion total cost is $360.
