Modified spring perch needed for Hal struts/springs?
Do I need to modify the spring perch for front Hal struts and springs? As far as I know, you only need to do this when using different springs other then the Hals with QA1 struts. Is this correct?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Thunder told me that you only need the modified spring perch if you plan on using the stock springs. If you use a lower spring such as Eibach or other, you do not need them.
