60ft issues
1. your pinion angle what is it set at
2. that may be to loose of a converter if it was me with a setup like yours id go a lil tighter something in the 2600 to 2800 range.... trust me nitrous will make up for the lack of converter
3. i would recomend a set of qa1's all the way around and ditch the front sway bar
4. what kind of gear in the rear a th400 does not have the low gearing that the t56 does so you are losing some torque multiplication
5. tire size
6. tell us alil more about your setup and we can get you making faster 60fts than before!
the car has remove, ac, and ft sway bar... so probably around 3500ish it dynod 586tq@ 5000 and 601hp @ 6100
