Got my lower spring installed and have a problem!
Old Jul 7, 2009 | 09:59 AM
PONTIACTRANSAM94's Avatar
Default Got my lower spring installed and have a problem!
I installed my eibach pro kit on my 94 t/a yesterday and it sits 1/4 to a 1/2 inch lower on the passenger side has anyone ran into this with their car. I also put kyb agx shocks. And is there any way to correct this.
Old Jul 7, 2009 | 10:18 AM
z28bryan's Avatar
Search function must be broken again
Old Jul 7, 2009 | 10:29 AM
LS1W66's Avatar
Must be
Anyway the ride height difference right to left is NORMAL
Old Jul 7, 2009 | 12:18 PM
z28_n_tx's Avatar
it always is..... well atleast when i use it
Old Jul 9, 2009 | 10:14 AM
therealcreeper's Avatar
mine's quite a bit lower too, almost all of em do it
Old Jul 9, 2009 | 04:58 PM
xXSilencerXx's Avatar
Is it normal to have a difference of an inch? That's what's goin on with my dad's TA and we can't figure it out.
Old Jul 9, 2009 | 05:20 PM
JD_AMG's Avatar
An inch seems like quite a bit...
Do you guys have adjustable panhard bars?
Old Jul 9, 2009 | 05:36 PM
I got a panhard bar sitting in my garage but havent put it on yet
Old Jul 9, 2009 | 07:55 PM
goldmecham's Avatar
did you loosen the rear control arm and pan hard rod bolts full tank of gas and bounce it till it settles and then retighten the bolts to make sure your not having any bind in your suspension. because most the time when people lower the car they forget the suspension is suposed to be tightend under load at and you just took a inch plus off the height.
Old Jul 10, 2009 | 09:52 PM
Yep, and they were tightened up under per manufacturer's instructions.
It's the front that had this difference. I'm beginning to think the car was in an accident they didn't bother to mention when selling the car.
Old Jul 10, 2009 | 11:27 PM
no, it's normal. unless GM crashed all of them before selling.
