3rd gen Bilstein?
Old Jul 14, 2009 | 06:32 PM
transambroli's Avatar
Default 3rd gen Bilstein?
Ok so I got these bilstein sport shocks for a third gen in today; was told they fit 4th gen plus they do say their recommended for lowered cars. Anyways I noticed the shocks are a great deal shorter than the stock decarbon shocks, and I had to lower the jack to get the top nut on, just wondering if this is normal with bilsteins and is it safe before I put the other one on.
Here's a pic
Old Jul 14, 2009 | 06:34 PM
wannafbody's Avatar
You'll be OK.
Old Jul 14, 2009 | 06:39 PM
Wheew, glad to hear that; thanks
Old Jul 14, 2009 | 07:28 PM
87formy's Avatar
That's the whole point of the sport versions. They limit the suspension travel so the shorter lowering springs can't move around when the suspension is fully extended.
Old Jul 15, 2009 | 09:12 AM
Alex212's Avatar
I just installed the same ones....you'll be fine.
Old Jul 15, 2009 | 11:51 AM
Sam Strano's Avatar
LS1TECH Sponsor
Fella's..... You should note just because something is called "sport" doesn't make it so. In fact I find that valving inferior (and fwiw it's softer than) 3rd gen HD valving. And if the car isn't lowered then you should not be running a shorter shock as you limit your droop travel.
Can you use them? Yes. Do you have anywhere the the best choice, even just among Bilstein shocks? No.
__________________
