Loose Steering Wheel
It was definitely the pin. But it wasn't about tolerences increasing, rather the pin had back out.
Close inspection found some peening marks on the housing and the end of the existing pin. So we used a narrow ended punch and tapped the pin back into the housing and the slop went away.
We then re-peened in it place.
The real issue is the colum has to be stripped in order to do this. We're lucky as we strip the columns anyway for race car purboses. What a PITA it would be having to put it all back together again.
mine happened with GMC S15 Jimmy and it just kept getting worse. I didn't know what it was so I just started into it from the steering wheel, got that out of the way then blinker set and then it was obvious.
Good luck
