True Coilovers ?
Old Jul 16, 2009 | 07:59 AM
Thyme_CA's Avatar
Default True Coilovers ?
I was just wonder what my options for these are. I know LG makes a very nice product but I'm not even aware of anyone else ???
Ps. I've tried google
EDIT:
Sorry it's for a 4th Gen F-body.
Old Jul 16, 2009 | 08:52 AM
BillS's Avatar
global west and ground control also make coilover kits. the LG stuff is nice but pricey and the spring/shock valving is best for open track not autox
Old Jul 16, 2009 | 09:42 AM
EDS01SS's Avatar
QA1 also has a coilover setup. You can check them out at Byunspeed.
Old Jul 16, 2009 | 11:06 AM
racerfox's Avatar
heres were i got mine for autox and full road race email jason and tell him jesse sent you
http://www.unbalancedengineering.com/Camaro/
thats the link kinda $$ but there the best coil kit
Old Jul 16, 2009 | 12:20 PM
Sam Strano's Avatar
LS1TECH Sponsor
KW makes Variant 3's for the 4th gen: http://www.stranoparts.com/partdetai...D=20&ModelID=7
Split Double Adjustable dampers (separate compression and rebound damping), Coil-over front, adjustable perch rear (not coil-over shock, but height adjustable with the ability to change rates. In fact, I don't think a true coil-over rear is very smart, the shock and the shock mounting area of the body were never intended to carry the sprung weight of the car.
__________________
Old Jul 16, 2009 | 12:21 PM
Black_Z28's Avatar
Might want to say what kind of a car the coilovers would be going on.
Old Jul 16, 2009 | 12:24 PM
Big_Bird_WS6's Avatar
anyone make good rear coil over? i would love to do all four corners
Old Jul 16, 2009 | 12:32 PM
Sam Strano's Avatar
LS1TECH Sponsor
See my post #5....
What is so special about having all four corners be coil-over? I don't get it, enlighten me.
__________________
Old Jul 16, 2009 | 02:08 PM
00 Trans Ram's Avatar
Sam is right. Not only was that area never meant to carry the load, but it's on different sides of the axle. The stock spring perch is on the rear of the axle, and wants to tilt the axle backwards. All the suspension points are designed to counteract this.
The shock is on the front. If you put the spring up there, it will want to twist the axle forward, which is reinforcing what the suspension is doing.
However, if you are bent on doing coilovers in the rear, I'd look into putting the coilover where the springs currently are.
Old Jul 16, 2009 | 03:25 PM
z28bryan's Avatar
Interesting. Learned something new
Old Jul 16, 2009 | 07:34 PM
Major_Lee_Slow's Avatar
Ground Control makes "weight jackers" which are what is needed to get the adjustable ride height in the rear. Using them also allows our cars to use off the shelf stock car springs which can be had for $50.00/ea.
Attached Thumbnails True Coilovers ?-img_0155.jpg   True Coilovers ?-img_0010.jpg
Old Jul 17, 2009 | 06:42 AM
leadfoot4's Avatar
I saw some pictures, a LONG time ago, where Doug Rippe Motorsports was running a coil-over on the rear of a 4th gen. It was in place of the regular shock. I wasn't sure how that would work out, as I didn't think the unit structure was designed to take that kind of load in that particular location.
Old Jul 17, 2009 | 12:21 PM
Originally Posted by Sam Strano
See my post #5....
sam ,
i dont want it cuase it is special. i want to clean my *** end up. i got a show car. so i am getting MWC rear end and doing a watts from Eric. in the process i will delet the spring mounts. so the rear will look very clean.
__________________
and for all the other comments. if they werent a good idea. people wouldnt do them. hell i found out strange and Spohn both make a kit.
i was thinking of buy those Sphon weld in plates and then strange springs and shocks.
Old Jul 17, 2009 | 12:47 PM
I know you didn't just say that. People do stupid things EVERY DAY. Check out the "removed front swaybar and now my car sways" thread.
They can be made to work. But, you have to understand what's going on and take steps to correct the new set of problems that are created.
Old Jul 17, 2009 | 12:59 PM
^^^ lol. yeah i know. just wanted to put a little spice in my comment. lol people do do stupid ****.
_________________
but as long as i do it right. coil over should be fine.
Old Jul 18, 2009 | 12:40 AM
nosaj's Avatar
Are coilovers good for dragracing or are springs better?
Old Jul 18, 2009 | 02:59 PM
pewter2002's Avatar
Weight jackers? Great idea, looks like a quality piece! Oh my, $459 at JCwhitney!!!
Old Jul 19, 2009 | 11:00 AM
Thyme_CA's Avatar
Never thought of that, good point. How good is the KW stuff ?
Also I can't get globe West stuff because they don't ship to Canada as far as I know ...
Old Jul 19, 2009 | 02:00 PM
TrakJunky's Avatar
I just installed the ground control co's on my car with koni 4/4's, Fairly easy to install and you can specify spring rates (big plus for me im an auto-xer and i mess with my stuff a little bit) .. Great customer service as well.. Ive been dealing with them for a long time and they have never let me down.
P.S. if you go with konis you need a special tool to get the front tophats off so the coilover sleeve will fit onto the shock.. Or you can hack it up.. I used the first method.
Old Aug 17, 2009 | 07:44 AM
SpinsB's Avatar
Im confused on this. Can anyone explain. I thought coilovers where something different from koni's
