front suspension squeaking
What can i lube the bushings with so it will quiet down,i hear it while moving forward slowly.
Thanks in advance.
How do you plan on lubing your stockers? There are no zerks so you'll have to take them off or use a needle adaptor. You flat can't grease any of the other stock components as there are no provisions in the balljoints and other parts to my knowledge.
rubber, then grease needs to be a kind that won't
soften it up. An alternative here is powdered graphite,
like you get for lock work (not the spray can, the kind
that comes in the plastic tube).
I have not tried powdered graphite on rubber bushings but have used it to great effect on rod ends and lock mechanisms.
As a sidenote for people that don't know:Graphite in a rubbing alcohol suspension is great at freeing up frozen locks.
Does the graphite work as well with rubber as grease does?
