Line Lock setup pictues needed ! ! !
The base kit starts at 139.99 including the adjustable wilwood proportioning valve, preformed lines and every fitting you need.
If you want something custom, we can provide you with any fitting or component you need. Designing your own kit will have a sense of accomplishment but do not do it from a cost perspective. The valve alone will set you back ~55.00…you'll need quite a bit more to complete the setup.
