Questions before sway bar install
Old 07-06-2009, 02:39 AM
ls1owner4life's Avatar
Default Questions before sway bar install
Hey, are there any torque settings I need to know for the front and rear sway bars on my 02 camaro SS? Including the end link and mounts. Second is there anything else I need to know or any mistakes someone has made? Thanks!
Old 07-06-2009, 03:37 AM
94'BLKBRD's Avatar
16ftlbs for the mounts and 18ftlbs for the endlinks. It's recommended that the suspension be loaded when you tighten the endlinks. Don't over tighten the endlinks, they're good when the bushings start to bulge.
Took me 1 1/2 hrs to do my front and rear UMI bars on Friday. Take your time and good luck.
Old 07-06-2009, 03:55 AM
darknessxyz's Avatar
Plain and simple: http://www.ls1howto.com/index.php?article=22
Just make sure you put grease on the bush, not the endlink. Depends on with kinda spring you've, you might need to cut the spacer little. I've 1.2" drop so I cut the spacer off 1".
Old 07-06-2009, 03:47 PM
z28bryan's Avatar
For the rear, you might have to jack up a side a little to make the endlinks line up well. I had to the other day. Also the spacers given to you may not always be ideal depending on your ride height.
Old 07-06-2009, 11:37 PM
99Bluz28's Avatar
Just back/pull your car up on a good set of ramps. No need to pull the wheels!
Old 07-07-2009, 08:40 AM
Major_Lee_Slow's Avatar
Unless you are running 17x11's on all 4 corners
Old 07-07-2009, 09:05 AM
JamRWS6's Avatar
I've got some 14" wide race ramps
Old 07-07-2009, 09:13 AM
The ramps aren't the problem. There isn't enough room to easily wrench cause the tire is tucked in really far
Old 07-08-2009, 12:25 PM
99Bluz28's Avatar
Thumbs up
Good point!
Have you tried using some ratchet wrenches?
That's what I use which works great, but I have 18 x 9s so I've got more room.
Old 07-10-2009, 01:13 AM
metalmechanic's Avatar
my bolts didnt seem long enough so i had to use ratcheting tie down straps to pull the wheel up higher to get enough threads through the sleeve and bushing, washer, then get nut on
Old 07-10-2009, 01:23 AM
mhayes2344's Avatar
I assume you're talking about the end-links...would've been easier to just jack up the opposite side slightly. That's what I did and it worked fine.
Old 07-24-2009, 12:45 AM
Actually yes, that should work, but i was already on ramps
