Adjustable LCA?
Would it be correct to assume you mean "Panhard Bar", and not "Pitman Arm"??
The only thing I could see happening is if you move the rear axle too far one way or the other, using adj. LCAs, is that you could cause the panhard bar to be in a "bind", as it's attached to the chassis on the right side, and the rear axle on the left.
In theory, those mounts should be in line with each other, so the bar can pivot smoothly.
He's Right! If you have a stock or a non rod end PHB you will have the bushing in a bind..
Thanks
Brad
Like mentioned I would recommend an adjustable panhard bar with rod ends as well for this. Also you may need an adjustable torque arm to recheck and correct the pinion angle once you make that type of move... the pinion angle may change.
Here is an item to consider. It has the adjustment you need but also sets the control arm in 3/8" for additional tire clearance for the tire width, not sure what width you are going to be running- www.umiperformance.com/2017OF
If we can help anymore please ask. Thanks!
Did it screw up your pinion angle?
