no more wheel hop for 60 bucks
Old 08-12-2009, 09:24 PM
highway21's Avatar
Originally Posted by nerisls1z
what materials did you use ? angle iron or just regular steel cause my car is not so much with the wheel hop just when doing a burnout my rear slams into my bump stops....i think its from all that flex of everything ....let me know what type of stuff you used cause i am down to do mine!!!!!!GREAT WORK LOOKS AWESOME!!!!
it was done with steel 2 inch by 1/8th for the lower control arms... and 1 1/2 by 1/8th for the pan hard bar...
Old 08-12-2009, 09:30 PM
highway21's Avatar
Originally Posted by 2000Z28M6
good work...just remember poly will make those LCAs and PHB bind in fast transitions, like AX or RR. Probably works really well for drag though!
just an observation, but if you were seeing wheel hop on street tires, On street tires I doubt you have enough grip to actually flex the LCAs....however bushings were probably deflecting alot.
you wont fully know how well the boxed LCAs work until you get sticker tires.
With the streets a simple bushing change would of netted you the same results. Does it help you did all the work, well hell yes of course! Again just my 2 cents.
well when we took off the stock bushings they dam near came out by themselves... and i could twist the panhard bar and lower control arm just with my hands.. after the plates were installed it fixed all that.. i was taking them out anyways to replace the bushings.. so might as well weld a plate in there b4 i put them back in..
Old 08-12-2009, 09:32 PM
highway21's Avatar
Originally Posted by WYATT318MOPAR
Anyone want to explain this to me. Why would any kind of panhard bar for that matter have an effect on breaking a 10 bolt? Even though I am only using mine for gear testing right now I run the *** off my 10 bolt and have Burkhardt 4340 lca's and panhard. Something that corrects geometry and eliminates deflection allowed by stock stamped parts doesn't increase component failure.
the guy that made that statment really didnt know what he was talking about i guess
Old 08-12-2009, 09:43 PM
2000Z28M6's Avatar
Dont neglect the fact you had new poly bushings, again I dont doubt this was a good helpful mod...., but without the proper tires, you wont know if this meets the strength of after market LCAs.
Hey man, I'm with you I will consider this if I ever get a welder or time to get a friend to do it. Kudos!
Old 08-13-2009, 12:28 PM
highway21's Avatar
well i see what your saying.. i still need traction regardless lol.. 13.7 at 108mph with a 2.3 60ft is horrible for a just exhaust ls1 m6..well in my eyes it is.. and your camaro is really lite lol.. did you make that thing go on a diet?
Old 08-19-2009, 02:10 AM
SIC LSX's Avatar
for the time took i would of just paid the extra $ for real adjustable ones
Old 08-19-2009, 02:45 AM
flippincamaro's Avatar
Looks great man, Good job on doing it yourslef an as for the comment on the time taken to make you woulda just bought some, Well if your not doing nothingelse then your time is free, So why waste on buying some. Again to the op good job man,
Old 08-19-2009, 03:08 PM
robsquikz28's Avatar
that will not break the rearend
Old 08-19-2009, 03:12 PM
that job looks great man and I guarantee you that strengthened the **** out of those arms and panhard bar....I know from personal experience with putting in new bushings and boxing them..we had a car that was cutting 1.5x 60s on stock arms all day and then finally sold them to put in better arms. So dont let other haters tell you they wont work, there are people who ran this setup for very long time, its a old school trick that racers have been doing for years and it works
Old 08-19-2009, 05:24 PM
PlatnumStatuz's Avatar
pimpin
Old 08-19-2009, 10:44 PM
nerisls1z's Avatar
dont worry bout the haters brother I am with you I just finished up mine sunday an a total difference next thing is bump stop's lol mine are trashed!
Old 08-20-2009, 04:18 AM
  #32
Ironxcross's Avatar
I have aftermarket poly LCAs for sale if anyone is interested
Old 08-20-2009, 05:50 AM
  #33
taws6's Avatar
I agree, much better to pay the extra and buy quality aftermarket parts, and if shipping parts to the UK wasn't so expensive, I would of done so.
FWIW, when I replaced my stock bushings, they may have been old, but they were still in great condition, and I felt a nice differance with the poly installed.
Just trying to state that although some of the differance Highway felt might of been due to the fact that his stock bushings were shot, mine were not shot, and I thought it was worth the swap.
And I'm sure the welds from the boxing of them will hold even if/when tires are added. I'm definately going to box mine too.
So IMO, the poly is worth swapping, even if your bushings are in good condition, but I would of prefered to buy aftermarket parts all the same....
Just my 2 pence
Old 08-21-2009, 09:30 AM
  #34
ahhwataday's Avatar
You work on lowriders? This is what you do when you are running hydros.
I think you could just as easily find some tubing somewhere and make your own tubular adjustable or non adjustable LCA and PHB, But nice work. Glad to see you DIY instead of spend a ton.
You can box in the Ends that mount to the frame and rear, cut them off the stamped bar, weld in a tube.
Old 08-22-2009, 03:31 PM
  #35
highway21's Avatar
well ya i wish i had the money to buy them.. would rather put that money towards my 9" that im almost have enough money for..im like 300 bucks away!! wish me luck
Old 08-22-2009, 03:33 PM
  #36
highway21's Avatar
thanks man, was bored and still had 1 day b4 the track.. so figured what the hell
Old 08-22-2009, 03:37 PM
  #37
highway21's Avatar
thanks for the positive feedback.. im going back to the track with mickeys on to see what kind of 60fts i can get.. on street tires i was getting 2.3's all day long.. horrible. yea my 5.0 buddies do it all the time, even though i bought lower and upper ones for my 5.0.. didn't really think nothing of it, till im broke and only have one day to solve my massive wheel hop issues lol..
Old 08-22-2009, 03:39 PM
  #38
highway21's Avatar
good to hear man, alot more people should do this mod if there on a budget.. its like night and day. i wasn't really worried about the bump stop since i have stock ride height and mine looked ok..good luck
Old 08-22-2009, 03:42 PM
  #39
highway21's Avatar
i don't work on low riders but would be cool.. i could have made my own tubular custom ones but was in a time frame of 1 day..will look into doing the one that mounts to the frame..
Old 08-22-2009, 03:43 PM
  #40
highway21's Avatar
going to put on my lca relocation brackets today so will update with picks.. thanks again guys for all the positive feed back
Quick Reply: no more wheel hop for 60 bucks
