BMR torque arm relocation kit for 4L60E?
Do any of you have pictures of your TA relocation kit installed. I plan to order it in the next week and would like to see your setups installed and what position you installed the torque arm. My car is a track car and i want to get the most aggressive angle on the arm as i can for the track.
Did a search but that was like a kid waiting to see Santa Clause.
LS1Tech Premium Sponsor
I don't have a picture of the crossmember installed. The higher up you install the arm the harder it will hit the tires. A good starting point is the fourth hole from the bottom. Every car is different they all react differently to an adjustment. Make sure that you check your pinion angle every time you make a change. If you have any questions please give me a call.
