safe to drive this way?
if i did pull the nut thru the isolator, is it safe to drive on for a little while until i can get a few more parts to do my koni/strano swap?
You've probably been without an isolator for some time now...the same thing happened to me...what you see in your spring is the metal sleeve that was bonded into the shock mount. You need both a new Isolator and strut mount. Also, be careful when replacing these....the only thing keeping your spring compressed is the weight of the car now. Once you start removing things it will extend more than normal without the nut to retain it in the mount so its going to be very frustrating. Have fun!
