energy suspension lube question
I just received a full bushing kit and have a quick question. The kit comes with lube and the directions say to lube all areas where metal touches the bushing. However, for example, the control arm bushings are already together...am I supposed to press the pieces out to lube the areas described in the directions? By together I mean the inner sleeve comes assembled in the bushing and the bushing is installed in the outer shell...THANKS!
