Need help with rear end problem
Old Sep 6, 2009 | 02:43 PM
Dulgrani's Avatar
Default Need help with rear end problem
The rear end is making a clunk sound when taking off quickly. I have replaced the axle bearings, brake caliper, brakes, rotor and the clunk is still there. Everything looks ok underneath so I'm really confused on what the problem could be. So any help would be highly appreciated. And also the car feels loose in the rear, kinda like it wants to sway back and forth
Old Sep 23, 2009 | 09:46 PM
Wesmanw02's Avatar
Check the torque arm bolts on the rear housing to see if they are tight, and also check the torque arm mount on the side of the transmission to make sure its in good shape.
Bad torque arm components will definitely make clunking sounds.
Also check your trailing arms and panhard rod for bad bushings.
Old Sep 24, 2009 | 07:21 AM
UMI Sales's Avatar
Hello
Just another thought for you. Check the hardware on the lower control arms and pan hard bar and make sure they are tight or the bushings might be bad. If not you will have to replace them. If you have any other questions leave me know and I will be sure to help!
Thanks
Brad
Old Sep 24, 2009 | 11:05 AM
Major_Lee_Slow's Avatar
Also check your parking brake as well as your exhaust for adequate clearance. I chased a cluck for a long time just to find out it was the exhaust hitting the chassis behind the axle.
Old Sep 26, 2009 | 12:23 PM
Nightrydass's Avatar
Lightbulb
Mine was still making a clicking even after i rebuilt my front end. I crawled under my car today to check out my rear bushings and found out my TRQ Arm bolts were loose on the pumpkin. I tighgten then down, and the click/clunk went away in the back.
Check 'em out, my car has 92K miles on it and they were never checked.
Old Sep 26, 2009 | 06:56 PM
adam1803's Avatar
U-joints could be what your hearing too, but it wouldn't account for the rear swaying.
Old Sep 27, 2009 | 01:39 AM
SOMbitch's Avatar
If you have an aftermarket exhaust that would be my bet...If not loose TA
Old Sep 27, 2009 | 11:16 AM
ODAWG's Avatar
check the transmission mount, rubber may be worn out.
