bump stop for Ypipes
Old Sep 12, 2009 | 10:11 AM
matt427's Avatar
Default bump stop for Ypipes
does anyone have a bump stop for the Y pipes to stop hitting the floorboard? if so can i see a pic of what it looks like? thanks
Old Sep 12, 2009 | 11:31 AM
Caribe's Avatar
Thunder Racing has them. Scroll towards the bottom:
http://www.thunderracing.com/catalog...&vid=3&pcid=54
Here is a pic of mine installed:
Old Sep 12, 2009 | 12:14 PM
matt427's Avatar
hows that work? the rubber is off to the side..my Ypipe hits the floorboard
Old Sep 12, 2009 | 12:16 PM
Charlay's Avatar
What part of the Y pipe does that sit on? Where the crossmember was?
Old Sep 12, 2009 | 12:27 PM
Redta00's Avatar
The back bracket just bolts in under the car right? Makes it more solid and doesn't allow the Y-pipe to bounce/flex.
Old Sep 12, 2009 | 12:35 PM
99Bluz28's Avatar
That the Mufflex bracket, just scroll down to the bottom of the page.
http://www.mufflex-performance.com/fbody_9.html
Old Sep 12, 2009 | 04:07 PM
Caribe's Avatar
It bolts with an existing bolt on the heat shield underneath the drivers seat. It just keeps the yipe from hitting in that area. Worked good for me, but others were not as lucky.
Old Sep 14, 2009 | 01:08 PM
matt427's Avatar
how does it only work for some?
Old Sep 14, 2009 | 02:10 PM
jimmyblue's Avatar
Moderator
I put a hose clamp through a piece of heater
hose, at one of the sheet metal bosses that is
a close approach. Seems to work well enough,
meaning no KR on a full stomp.
Old Sep 14, 2009 | 06:52 PM
Badguy7's Avatar
Do you need just 1 or 2?? Ever since i dumped my exhaust, my y pipes banging alot more. Just wondering if you guys put 1 on each side of the y or is it just 1 side that is usually causing the banging??
Old Sep 14, 2009 | 07:11 PM
meine96ws6's Avatar
wow, should have though of that.. mine rattles
Old Sep 14, 2009 | 07:35 PM
Caribe's Avatar
Some people put the bumpstop on, but still have problems with the y-pipe banging the floorboard.
Old Sep 14, 2009 | 08:54 PM
Redta00's Avatar
It is bolted in wrong then, or the bracket is attached wrong somehow. Those things should be bullet proof.
