Brakes dragging in the back?
Old Sep 20, 2009 | 04:27 PM
86formula's Avatar
Default Brakes dragging in the back?
i have a 96 camaro and the back brakes are dragging bad to the point where i can barely push the car (3k lbs without me in it should roll fine) i have no ebrake so i know its not that and the piston was pushed all the way back in with a clamp before i put the new pads on... any ideas?
Old Sep 20, 2009 | 08:43 PM
86formula's Avatar
Anyone?
Old Sep 20, 2009 | 08:51 PM
therealcreeper's Avatar
when you compressed the piston did you take off the brake fluid reservoir cap?
Old Sep 20, 2009 | 09:24 PM
86formula's Avatar
yup
Old Sep 21, 2009 | 10:34 AM
86formula's Avatar
I'm going to take the rear brakes off today and grease everything and see if I notice anything. Any ideas guys?
Old Sep 21, 2009 | 10:42 AM
Dewey's Avatar
wrong pads, probably. did you have to force the calipers back on or did they slip on without a fuss?
Old Sep 21, 2009 | 11:32 AM
86formula's Avatar
slipped on with no problem. They were dragging prior to putting the new ones on but I thought it was the ebrake (Now removed)
Old Sep 21, 2009 | 01:36 PM
Dewey's Avatar
bleed the brakes?
Old Sep 21, 2009 | 02:06 PM
Major_Lee_Slow's Avatar
I think your on the right path here.
Old Sep 22, 2009 | 07:41 AM
86formula's Avatar
Wrong rotors, they were too deep and were rubbing the caliper bracket
Old Sep 22, 2009 | 07:43 AM
That's a new one. Where did you get them from if I may ask?
