Sebring mod list for DD
Improved Racing oil baffle
Strano bars
eaton posi, or lightweight 9?
Oil cooler
Alignment
Watts link
c5 brakes? or brembo blanks with hawk ceramics?
I already have kyb agx's, strano springs, fidanza aluminum flywheel and 4.3 clutch, tick master. I'm just wondering what else I should look out for since it will be running sustained high rpm's. I'm guessing I'm going to need an oil pressure gauge and temp sensor
Heres the track map
http://www.sebringraceway.com/images...ckMap-2008.pdf
What kind of tires do you plan on using/what g levels are you going to be seeing? I think that is the main thing.
Plus there's alot of other good threads on setting up an F-body for road racing there as well.
