i have a slight predicament
i did a drivetrain swap into a 94 ta.
i am planning on driving it to a shop less than a mile away to have the rear brake lines redone (using ebrake to stop). I know its not the safest idea on the planet but i cant afford the towing.
my main predicament is that the bolt on the passenger side for the panhard
bar is busted and is frozen in the hole. should i hook up the panhard rod anyway for the 1 mile trip (bolt will be removed at shop) or leave it disconnected?
Hello
I will be able to give you a suggestion for the pan hard bar! Yes I would hook it up due to it is what keeps the rear end centered. And keeps the tires from having any clearance issues.
Hope that helps
Thanks
Brad
Hope that helps
Thanks
Brad
