f-body autocross questions
1. What is the recommended pinion angle for this type of racing?
2. Is my strut bar really doing anything for me when I have a strano front sway bar and SFC's?
3. For KONI SA guys, how stiff are you set up front?
I ran auto-x today and the car was pushing pretty hard in the corners, I believe my camber/tire pressure to be correct but Im definitely thinking I need to stiffen the front shocks.
tires will make the biggest differance in autox handling, not alignment specs. until you run slicks, if youre pushing on street tires, youre going to fast.
every tire is different. start somewhere, and work around it, increasing or decreasing as needed. dont take anyones numbers as gospel and never use anything different.
a STB isnt going to hurt anything. i have one with welded SFC and bars/shocks/springs.
