Stock rear spring help
Can anyone help with info on this stock camaro / firebird rear spring. In the picture starting at the far left is a spring with the tag and numbers 22077421 / TTJ. The second spring from the left is a 10305134 / NNU if I'm not mistaken on the letters. Then the third spring from the left is the one in question. As you can see it is shorter than the others and has not been cut. Near the top of the spring it has a rubber/plastic sleeve. On this sleeve it has the number 22133048 and does not have and other tag or number. Anyone have any info on this spring. The fourth spring (blue in color) is a SLP spring. See pictures below
