Brake pedal goes almost to the floor after engine starts
This is on my neighbor's 98 Accord. I got in it today with the engine not running. Pedal felt fine. With my foot still on the pedal, I started the engine. The pedal went almost to the floor. He told me he had been pumping the pedal to get it to stop when he drives it.
I had three thoughts:
1) Vacuum leak, causing havoc with the brake booster.
2) Bad booster.
3) Air in the system, with a possible leak since he said has been getting worse. But the MC is still full of fluid, and prior to starting, the pedal felt fine to me.
Any help would be appreciated.
2) Bad booster.
The problem isn't the booster. If the booster is bad you will lose assist, it will not cause the pedal to drop to the floor. You would just need a lot more pedal pressure to stop the car.
O.K., the master cylinder did not fix it. There aren't that many parts left. It does not have ABS, the rear cylinders do not appear to be leaking (nor is the master cylinder loosing fluid. Air in lines or booster. (Disclaimer, I did not bleed the brakes, he did.)
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
Not much you can do besides pull the master cylinder back out of the car and re-bleed it. Just about all reman/new master cylinders come with bleeder kits and instructions on how do to it. Basically you install the included plastic fittings into the ports, run the plastic hoses from the fittings to the reservior, fill the reservior with fluid, and work the pushrod until you don't see any more air bubbles in the hoses. Then the master cylinder is bench bled and ready to be installed. Then you have to bleed the rest of the system as usual.
There are only 3 things that will cause the pedal to go to the floor - a defective master, a leak in the system, or air in the system. Consider that when you diagnosis the car.
