having too much trouble trying to find an adapter
My proportioning valve only has 3/8"-24 fittings coming out it:
My rear brake line fitting is M12x1.5:
This is on 6mm line. Does anyone know how can I adapt the M12x1.5 fitting to a 3/8"-24? I've been trying to find an adapter but I'm having no luck at all.
Thanks for any help/advice!
I'm not sure what you're trying to build I don't think you'll find a direct fitting stock shelved as such. If this is an LS1 or LT1 F-body, it would have been easier and less expensive to purchase one of our ABS delete kits.
Only thing I can suggest is cut the fitting off and start fresh...or replace the whole line.
Dammit. Now you guys tell me. lol I guess I was trying to make my own ABS delete kit. Steve, I'm calling you tomorrow.
In the meantime I will pray to the gods of SJM Manufacturing.
Thanks for responding too, I know this isn't the most exciting fbody question, so I appreciate the responses!
