Coming Soon!- New Sphercial Bushing available from UMI Performance
We actually have most items in stock, just processing pictures now. Do you know what you are looking for.. I can sell them now if you want
These bushings are very street friendly, this is what they are designed for. For these applications I would recommend the polyurethane bushings on one end and new Roto-Joint's on the other end, these are excellent on the street. This type of set-up retails for $179.99 a set and I will have pictures this week
ryan PM me. details.
thanks
d
Here are a few more pictures. Just about all the products are completed... we are just processing pictures, building ad's and pricing. We will have these up the end of next week.
These item below will be installed in our adjustable components. It will also replace 3/4"-16 rod ends if needed in previous items and other brand items. We will be offering all our adjustable items with these new ends.
http://www.umiperformance.com/catalo.../0011a_LRG.jpg
http://www.umiperformance.com/catalo...0011ab_LRG.jpg
if they will fit those LCA's, how much are these replacement rod ends gonna be?
if they will not fit, are there going to be separate pieces in the future that will fit these older LCA's?
Ryan, two things.
1st.
can you pm me a price on the replace meant of my rod ends on my lower arms. so i can send a check with the rod ends. back to to.
2nd.
will those welded studs hold up? only reason i ask is i know like qa1 and the other rod end companies have those studs cast on then machined down. so does Spohn in his delfi style. i just dont want my arms to come lose cuase the stud broke off the round tube you have it wleded too.
thanks
d
1st.
2nd.
thanks
d
so these rod-ends will or will not fit in our previously-purchased single adjustable LCA's here?
The ends will be available in our aftermarket A-Arms. The factory A-Arm I mentioned I would look out.. however the factory items use different hole sizes so installing these items in there isn't that easy. The factory arms will most likely require an entire different size. I will take a look when I get a chance.
Ryan, two things.
1st.
2nd.
thanks
d
1st.
2nd.
thanks
d
Yes the welded end will be just fine. It is built from 4140 steel and TIG welded. Castings are nice however these companies using castings are not making there castings in-house, heck they could be built over sea's but I can't confirm that. UMI likes to manufacture all items in our facility and a fabricated end is our specialty. We have no doubt in it.
Price for a threaded end will be $45 each.. I will get more information shortly
Thanks everyone!
Ryan
#32
^^ thank you. i called and talked to terry( maybe jerry) about htem. they sound great. i for sure will be changing them out.
you guy( terry or jerry) said that the arm pieces wont be done for a month. can you comfirm this? if so that is fine. i can wait for a great looking piece.
thanks
d
thanks
d
#33
1) when will we be able to place an order for just the new rod-ends on the website?
2) if we purchased the new mounting hardware with our previous UMI LCA's, will that same hardware still work, or do we need to go back to the stock-sized bolts? i know there was an issue where the stock bolts with your LCA's would sometimes allow enough slop to cause it to rattle/clank around back there, and i want to make sure to use the right size mounting hardware.
#34
Hope that helps!
Ryan
#35
Wow - good looking piece of work! It makes me wish I had waited prior to my purchase.
(But isn't that always how it goes? You buy, then the "New and Improved" version comes along.)
Again, nice work! (Covet, covet, covet.)
#36
Looks like this is a big sale weekend. I would like to get a LCA with a polyurethane bushings on one end and new Roto-Joint's on the other end. with 15 % off and free shipping? Chrome-Moly please?
#37
I agree with this as well! The factory rubber castor bushings wear too quickly and poly creates too much bind, and also wears even quicker which causes a lot of play. One of these for the castor bushing replacement would sell like hotcakes in the autox/RR community!
#38
