longer wheel studs...
Old Nov 12, 2009 | 02:27 PM
johnLs1camaro's Avatar
Default longer wheel studs...
I am building a rearend for my car, which is going to be about 1.5 inches then a fbody rear on the each side. Which means I have to change my backspacing for wheels or run a spacer.. Id really like to keep my current wheels. My question is with having spacers and longer wheel studs is it more dangerous or at a risk of breaking on a fast-hard launching car?
Old Nov 12, 2009 | 02:59 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
Extended wheel studs are designed for hard launching. Make sure that if you use a spacer that it centers itself by using the axle hub instead using the studs to center itself.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Nov 12, 2009 | 10:10 PM
mitchntx's Avatar
ARP studs are recommended
7713 - $28.75
Pack of five 3.25" long studs
7703 - $10.99
Pack of five 2.5 long studs
The 7703s are basically the same length as the stock F-Car wheel stud, just threaded all the way to the end. Using a 1/2" spacer is just a tick too thick for these.
Old Nov 14, 2009 | 08:52 PM
blk96406's Avatar
If you are building a rearend for your car, and you wanna run the wheels you have, why are you building it 3" narrower than what it is now??? What are you building/putting together for it????
Old Nov 14, 2009 | 11:25 PM
^ doing the 8.8 man.. its that much shorter.
