Will new suspension setup stop tire rub?
Right now my 99 SS has stock suspension (69,000 miles) but has 18" ZO6s with 295/35/18 Goodyear F1s on the rear. My problem is that when I turn, like into a parking lot that is slightly elevated, my tire rubs on the fender just a little. When I turn left the left rear tire rubs and when turning right the right rear does it. It happens once every couple weeks or so, but its annoying. Just looking at the car when parked there seems to be so much room between the tire and the fender (too much IMO - if I really wanted that look I would've bought a 4x4 truck). I want new suspension anyway and I have been looking at the Strano setup with Bilsteins. Will the new setup eliminate the tire rub or will I have to roll the fenders?
Hello,
You are talking about the rear tires correct?
The main issue is most likely the fact that the rear end is off center and this usually causes rubbing on side of the car. What you need is an adjustable panhard bar which will allow you to center the rear end under the car.. this would then eliminate the tire rubbing issues you are having. Centering the rear end is very easy and can be done using a tape measure.
Below I posted a link to the items we offer. If you have any questions please ask.
http://www.umiperformance.com/catalo...Path=7_138_106
Hope that helps!
Ryan
Hope that helps!
Ryan
http://www.umiperformance.com/catalo...=index&cPath=7
If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
